07-13-2019 01:39 PM - edited 01-05-2022 05:52 AM
Everytime I try to download a text picture message it wont do it. After 2 trys this comes on the screen "currently unable to download try again later. How can I make it work have been on P.M. approx one month and hasnt worked once.
07-13-2019 05:18 PM
@pmimin2404 wrote:Not too sure how to do a screen shot?
Press power button and down volume button at the same time and hold down for a second.
07-13-2019 05:11 PM
07-13-2019 05:10 PM
I have the forty dollar plan. Data shouldnt be a problem. I did the APN set up and a few things didn't stay on. Will do the process again.
07-13-2019 03:11 PM
@pmimin2404 wrote:Everytime I try to download a text picture message it wont do it. After 2 trys this comes on the screen "currently unable to download try again later. How can I make it work have been on P.M. approx one month and hasnt worked once.
@pmimin2404 Maybe post a screenshot of your apn settings. That might help us determine what the issue might be. 🙂
07-13-2019 02:58 PM
By the way, my last phone was a Galaxy S3 and if it hadn't fallen off the roof of my car and got run over by a dumptruck, I'd likely still be using it. An oldie (in cellphone terms) but a goodie !
07-13-2019 02:56 PM
Just to mention in case the user doesn't now, there are no data overages with Public Mobile. If you have no paid data, no paid data will be used or charged. Therefore, in the case of the $10 plan, you can leave your data on all the time and your MMS will kick in when it needs to.
If you ever decide to get say the $15 plan with 250 mb of data, I'd turn it on and off each time you need it as I've seen lots of people turn data on for MMS and then find a large chuck of their data gone the next day. Not to mention the huge OVERAGE charges other cell providers charge.
07-13-2019 02:09 PM
07-13-2019 02:06 PM
07-13-2019 02:05 PM
@mimmo so are you saying you can send and receive mms on the 10 dollar plan?
07-13-2019 02:03 PM
@RossN wrote:@pmimin2404 Hi you must have you data on to receive or send mms messages and also be on a plan with data
@RossN you do not need a data Plan for mms just the correct apn settings.
07-13-2019 01:44 PM
07-13-2019 01:44 PM
you probably need to set /reset your apn settings. also is data turned on? data needs to be on to receive mms
check out this thread:
