SIM Network Locked
moonunit
@Jackhyf63 wrote:
@moonunit
if your sim is locked, you will need to contact a member of the Modertator Team to get the puk code to unlock the sim and choose a new 4-digit pin.
When contacting the Mod Team, be sure to include your name, sim number, account number, and account pin.
Not correct:
"SIM network PIN blocked. Enter SIM network PUK." is asking for the phone’s (often Samsung) “master code" after entering the wrong code too many times. Samsung and/or your previous carrier can give you this.
"SIM network unlock PIN" is asking for your previous carrier's unlock code - just contact them with your IMEI and they'll give it to you. If you enter this incorrectly too many times, you'll get the error message above.
“PIN unlock key (PUK)” is a SIM-specific code used to prevent unauthorised use of a SIM card.
The PIN (Personal Identification Number) enables secure access to the SIM card and network. It is provided with your SIM card.
  • If the PIN code is entered incorrectly 3 times, the phone is locked (except for emergency calls) and requires a PUK (Personal Unlock Key) to reactivate it.
  • Once the PUK is recovered and validated, you will be asked to choose a new PIN.
  • Only Public Mobile's moderators can give you this type of code, which the device manufacturer cannot. Public Mobile's moderators can be contacted at the following address: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
  • Caution! If the PUK is entered incorrectly ten times in a row, the SIM card becomes unusable.
Jackhyf63
@moonunit
wetcoaster
This message on your screen means that your phone is locked to your previous provider. You have to contact them to get the unlock key.
RossN
