10-06-2021 10:58 PM - edited 01-06-2022 03:43 AM
Hi, Wanted to check whether if my phone, Samsung SM-J610F, is compatible with the public mobile network, I don't know how to check, my phone is not listed in Public mobiles check the compatibility of public mobile network.
10-07-2021 04:36 PM
Public Mobile uses the following frequency bands:
Good Luck
10-07-2021 01:12 AM
@hTideGnowThank you for clarifying the source of the incorrect information. I apologize for misunderstanding that the screenshot was pertaining to a different phone model.
10-07-2021 12:23 AM
@shimdog wrote:If it's not listed then it's not officially supported. In my past experience, the only way to know for sure is to try it but i understand that may not be practical.
Pretty much no phones are officially support by Public Mobile. With the exception of the current CPO offerings, Public Mobile isn't in the business of selling devices. This means that no testing is being done to ensure compatibility. Also, device compatibility lists will always be incomplete.
10-07-2021 12:19 AM
10-07-2021 12:16 AM - edited 10-07-2021 12:27 AM
what you meant by it is not on the list? yes, it is not on the PM Compatible list .. but I am not just post a screenshot of any different phone at random.
this is my source,
(I have to use the screenshot for the address as PM has been putting my post to unmoderated item)
the datasheet on the page did confirm the model number
Many members here use Kimovil as a reference and I am certain they recognize the screenshot is from there. I am not saying Kimoli cannot be wrong, in fact we found its mistakes in couple occasions. But please do not say I post "screenshot of any different phone's information picked at random". I am definitely offended
All speculative information is potentially misinformation. Please be careful about this in the future.
What make you think I am not careful? I have spent quiet some time to do my research for OP.
Also, my stance is, if I have doubt, I don't suggest user to buy it as I worry about them go out and took the wrong advice and wasted money. This was exactly what I was saying in my original post and my follow up post. So, I have been careful and take my words very seriously
10-07-2021 12:07 AM
@hTideGnowIf OP's phone model is not in the list then why would you just post a screenshot of any different phone's information picked at random? All speculative information is potentially misinformation. Please be careful about this in the future.
I've cited my sources of information. If you have any conflicting information to share, please cite yours.
10-07-2021 12:04 AM
Please note that it doesn't support LTE bands 4, 12, 13, 17, nor 29 (but does support band 7) so 4G-LTE support will be limited for this phone on the Public Mobile network.
10-07-2021 12:01 AM - edited 10-07-2021 12:03 AM
@0PX9O4 the PM Compatibility list does not include every phone, so, a phone cannot be found there would not mean much.
I also found mixed information about the Band 2 on 3G. But I would be more cautious. If OP need to buy it now and test it, I would more into not recommending that, just in case, better safe than sorry. If OP already has the phone, then why not, just test it out.
Also, if OP needs to buy it and we have mixed info (or lack or solid info), I would go out and buy one that we are sure it works here well.
10-06-2021 11:55 PM
It doesn't look like the J6+ was ever sold in the US, so I'm not sure what to make of that American vs Global version in the screenshot. Also, the J6+ is not listed on the PM compatibility checker, so it's possible the information in the screenshot pertains to a different model altogether.
Looking at multiple sites (links below), it looks like the Galaxy J6+ SM-J610F does support both 850 as well as 1900 bands so you should be okay to use it on Public Mobile anywhere in Canada.
https://www.gsmarena.com/samsung_galaxy_j6+-9334.php
https://deviceatlas.com/device-data/devices/samsung/sm-j610f-ds/41449491
10-06-2021 11:21 PM - edited 10-06-2021 11:23 PM
@hTideGnow wrote:If it is Global version, it might be issue with voice. It only has B5 and lack B2 on 3G. With one less 3G band, you might experience drop calls issue 4G bands on this Global version is ok. It does have B2, B5 and B7
I'll go a step further than that.
Do not purchase any phone that doesn't have both band 2 and band 5 for 3g. Especially when lacking band 2 for the HSPA+ network, you may even encounter many places where you can't make or receive phone calls at all. There are some regiions within Canada that are either predominantly or excluslively on band 2 for the HSPA network.
10-06-2021 11:15 PM - edited 10-06-2021 11:17 PM
@Dasmesh is your Samsung J6+ a Global version or American version?
American version should work well.
