Samsung Galaxy A50 - compatible with public mobile's network?
Korkai
Hi,
My dad wants to switch to public mobile.  His phone, Samsung Galaxy A50, is not listed on the compatibility list.  Can someone please confirm whether or not his phone is compatible with public mobile's network. Thanks.
10 REPLIES 10
Korkai
Great tip. Thanks a lot!
Korkai
Thanks for your reply.
Yummy
Are you PM client? Easiest way to verify will his phone work is to put your PM SIM into his phone and confirm. I am sure his phone will work based on specs.
@Korkai wrote:
My dad said his model number was SM-A505W. This will work? Thanks.
Yes. The "W" denotes a Canadian version of the model.
Korkai
Korkai
Thanks very much for your reply.
Korkai
Thank you very much.
@Korkai   Here are the bands on your phone .. and BOLD are the bands compatible on PM
SM-A505U would be better but the other variant works too
3G bands SM-A505U :      HSDPA 850 / 900 / 1700(AWS) / 1900 / 2100 -
                  Other version:  HSDPA 850 / 900 / 1900 / 2100
4G bands   SM-A505U:        1, 2, 3, 4, 5, 7, 12, 13, 17, 20, 26, 29, 38, 40, 41, 66, 71
                  Other version:    1, 3, 5, 7, 8, 20, 38, 40, 41
@Korkai
Yes, the Samsung A50 is compatible with PM.
Try conducting a search under Samsung Galaxy A5 (older version of A50).
@Korkai yes, A50 is compatible on PM
Best if you get a North American version, but other variant should work here as well
