09-12-2019 01:52 PM - edited 01-05-2022 07:03 AM
I might be getting a good deal on the Samsung A5. Will it work with public mobile?
Phones
09-24-2019 03:24 PM
@darlicious wrote:
@jimbobs wrote:
@derekt wrote:Great. I have a SM-A520W as well. Over all, do you have any issues? I plan to swap my simm and setup soon.
No issues at all. I activated the SIM online, put it into the A5 and was up and running in a few minutes. All the settings are available in this forum and elsewhere.
Great phone has an excellent camera...except in night conditions for some reason unless I'm missing something. Much better than the s7 ( I thought it was the other way around!). Great price too I think I paid $399+tax in Dec 2017. The Samsung s7 was almost twice the price.
I'd say the A5 has an OK camera rather than an "excellent" one. Outdoors in bright light is fine but in less bright situations it's not so good. Having said that, it is a single lens camera on a budget camera so nobody should, or can reasonably, expect a really good camera.
09-22-2019 02:24 PM
09-13-2019 09:32 PM
09-13-2019 09:05 AM - edited 09-13-2019 09:05 AM
Your model works 100% with Public Mobile.
09-13-2019 08:56 AM
09-12-2019 04:58 PM
Yes. I'm using an A5, model number SM-A520W on PM.
09-12-2019 01:57 PM
I have the A5 as well but the dual SIM (bought from foreign electronics.) Works great been using it with both my numbers to test it out and no issues so far in that regard.
09-12-2019 01:56 PM
@derekt wrote:I might be getting a good deal on the Samsung A5. Will it work with public mobile?
Yes, almost all models will work.
With the exception of sub-model: SM-A500H (3G network only, as this device does not support 4G LTE bands)
09-12-2019 01:53 PM - edited 09-12-2019 01:56 PM
@derekt, I assume you are purchasing the North American model? If so, it will definitely work. Run the sub-model number through this checker. All A5s have the right bands for 3G but SM-A500H does not support LTE.
09-12-2019 01:53 PM
Yes, works perfectly. I'm using one!
