SUBSCRIPTION NOT ACTIVATED
Kaanmert
Something didn't go right while activating your subscription. Click below to contact a customer support agent.
Get Support”
if I can …
2 REPLIES 2
slusagm
Try reboot the phone and re-login the app and see if the app can complete the activation.  If not, you will have to ask PM to help.   Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
hi @Kaanmert
are you activating esim or physical sim?
but you will need PM support agent to help..  You can submit  ticket by direct message:
