SOS - no service
03-02-2024 05:58 PM
Switched from Virgin to Public on Thurs and still no service/can't get a response from my ticket. I have restarted phone, reset the network settings, and still nothing. I already received email that Virgin got the notification to transfer my number, but I have zero Public service, please help!
Service
03-03-2024 03:16 PM
happy to see it all resolved @tchoo
yes, the support with PM is not bad, just need a bit of time 🙂
03-03-2024 03:14 PM
Waited an hour but still wasn't able to access My Account or the mobile app. I then let CS_Agent know and they were able to resolve it on their end. Everything is working now 🙂
03-03-2024 01:15 PM
thanks @tchoo for the update
for access My account on the browser, best to always use Incognito/private/secret mode on your browser and then you don't need to worry about cache problem
03-03-2024 01:14 PM
@Connor21 , CS_Agent got back to me and resolved my service issue on their end.
As for the mobile app and website issues, they told me to wait 1 hour, clear the browser cookie/cache and reinstall the app. 🤞
03-02-2024 06:22 PM
I'm running into the same/similar issue as OP.
Initiated the phone number port, got the sms confirming the transfer, phone picked up the eSIM. However, no cell service or data.
When I try to log into the mobile app, it infinite loops back to the login screen after entering my credentials. I've tried clearing app storage and cache, still nothing. When I try logging into https://myaccount.publicmobile.ca/, it gives me a "Forbidden A1" error message. When I try to make a call, it says I don't have an active plan.
I've sent a message to CS_Agent.
@Connor21 I'll keep you posted if they get back to me on the resolution. Hope you're able to get everything working soon.
03-02-2024 06:11 PM
03-02-2024 06:10 PM
hi @Connor21 check if the eSIM is on the phone and enabled. Check Sim Manager
03-02-2024 06:09 PM
could be just a eSIM setup problem on your phone
Did you get to the eSIM installation step? Either the app will ask for your permission to do it for you, or you can get the QR code to install yourself.
If you missed the step to install by the app, there is a QR code in your Welcome email. Open it from a computer, or another device, then use your phone to scan it to install the eSIM profile on your phone.
Once you installed the eSIM profile, (or If you got passed that step eSIM installation step), try to reboot your phone once.
If it still does not connect and if you have another active sim on the phone, disable those non PM sim (eSIM/Physical sim) using the SIM Manager on the phone or simply remove the physical sim.
And make sure the one associated with PM sim and your phone number is enabled.
(On iPhone: Settings->Cellular , make sure the PM eSIM is set as Primary on "Cellular Plan Label" and "Turn on This Line" is toggled on)
Then click Reset All Networks on your phone and it will work. (Please note that Reset all Networks will also erase your saved Wifi and Bluetooth connections, but you just need to add them back after). Also, it is possible you have to reset it multiple times for it to work.
if it still does not work, please open ticket with PM support
1. Open ticket via Chatbot (need access to My Account): At https://widget.telus.tiia.ai/publicmobile/publicmobile.html
Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Login" and finally click "Click here to submit a ticket ↗"
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
03-02-2024 06:05 PM
we chose the e-Sim option
03-02-2024 06:01 PM
hi @Connor21 it is not a porting problem but an account or sim setup problem
test the sim on another phone. If same, please submit a ticket with CS Agent here using Chatbot. Click on the bubble and start by typing "Submit ticket", Choose "Contact Us" and then "Other". If any issue with ticket submission, you can then submit by direct message:
