SMS
lily2024
Hi!
I want to know can I receive text message in China? And if yes how much will you charge for it?
hairbag1
@lily2024
if you have access to wifi or buy a travel data plan (airlo maybe)...consider downloading the free TextNow app. You'll select a free Cdn number so you can send / rec free messages and calls, using local wifi or separately purchased data. Did I mention it's free !!
@lily2024
You need to purchase a local SIM from China to get service like texting and calling within China because PM SIM will not work in China.
Mxt
Hi @lily2024
No PM does not offer international roaming except US and Mexico. It means you won't be able to receive any text messages in China. Hope it helps!
