3 hours ago
Hello,
I recently used an e-sim for my travel. I have disabled it and now I cannot send SMS. I have restarted my phone and I also took the sim out and put it back again.
What can I do next.
3 hours ago
what phone you have ?? Android or iPhone??
Check the phone and make sure you delete the travel esim profile, check VPN screen and remove all VPN profiles there. Then reboot phone and click Reset All Networks
if still does not work and if you are on Android, download Google Message and set it as the default messaging app (if you are using Google Message already, uninstall, reboot and reinstall)
3 hours ago
@MeetaG106 Check that your APN setting is SP.MB.COM
