SMS issue defying all known fixes.
Kootenay_boy
I am having a heck of a time with SMS not sending Ive tried every "fix" I can find in here the public mobile community, the chat bot / useless service ticket and Google.
I can receive SMS  my plan id sufficient, paid and working lots of data and home WiFi.
I cannot send SMS messages they always come back as not sent "check options, resend / delete"
This issue has been a problem for years and through multiple phones with the same phone number Ive uninstalled and reinstalled the SMS app Ive tried different apps Ive checked all the usual suspects in the settings. It has not worked so Im assuming it has to be on the public mobile end.  I normally use another messanger so I often just forget about SMS until I NEED it then remember poop it cannot send.
So Im there again and really want to get it cleared up once and for all any help beyond the normal would  be great Im fairly tech savvy not a hacker level but ok so it is either something stupid simple or way out there
Im stumped
cheers
1 REPLY 1
hairbag1
@Kootenay_boy
use this link to message Customer Support to have them investigate....
