08-22-2025
10:42 AM
08-22-2025
03:20 PM
computergeek541
Hi
Using IPhone 6+. Just created a new 4G account. But when I switch from 3g to LTE the Iphone still shows 3g.
As a test I swapped the SIM out with an existing Public Mobile account on a older IPhone SE and then I get LTE on
the IPhone 6+.
Any idea on how to fix this.
08-22-2025 05:01 PM - edited 08-22-2025 05:02 PM
The iPhone SE is a newer phone than the iPhone 6 so more features are likely to work.
08-22-2025 03:48 PM - edited 08-22-2025 03:49 PM
@Dunkman Brought up a good point about VoLTE on the iPhone 6+.
I have an old iPhone 6 and it is not VoLTE compatible so you will have issues making a call and receiving calls. My spouse had an old Samsung S8+ that was also not VoLTE compatible and all in coming calls were choppy and incoming calls goes straight to voice.
No problem with SMS texting though. Therefore, you can only use it for googling and texting.
You might want to upgrade your phone once all carriers decommission 3G.
08-22-2025 11:19 AM
Thank you for bringing this to our attention! The customer was already in a private conversation with one of our agents when the post was escalated. The agent will continue assisting them directly.
08-22-2025 11:04 AM
As a test I switched the SIM out with an existing PM account and that SIM show LTE on the IPhone 6+.
So the issue is not the Phone.
08-22-2025 10:55 AM
iPhone 6 is an older phone. Maybe try a network reset of your phone (note: this will erase any saved Wifi paswords).
Maybe check the VoLTE compatible checker:
https://www.publicmobile.ca/en/get-help/articles/volte
iPhone 6+ is unlikely to VoLTE compatible with PM network. Might have talk issues depending on your area.
