SIM invalid
johnschwenk7
Hi,
I am a returning member of the community, but as it has been awhile, I had to order a new SIM card. I got it in the mail today, and when I finished the Activate process and screen, I got an Error message that it was an Invalid SIM. I double checked and tried again, with no luck. Help! I need to get this active and get my number ported over before my previous employer disconnects my service!
8 REPLIES 8
fdrcamb519
I had the same problem, had to make sure all the fields were correct, and than still said invalid, tried a few more times it worked. that's my story..............😁
hairbag1
@johnschwenk7 wrote:
Hi,
When you can restart the Activation process...make sure to use a different email address than your previous account. If you're using a gmail account, you can also use alias. eg ...joeblow+1@gmail.
See if that helps. Good luck and welcome back.
BearFBI
Same here. Got the same issue. I guess have to try tommorow
gblackma
@johnschwenk7 check your credit card. If you were charged, insert your SIM card, and go see if your self service account was created.
If not, wait 1 hour from last attempt,  clear your browser history,  go to private/incognito mode and try again to activate your SIM card. When entering your debit/ credit card information:
1. Enter the credit card address exactly as it appears on your statement ( capitalize all if necessary ).
2. Leave the apartment field blank, if applicable enter your apt in the street address field ie xxx - street address.
3. Enter your postal code without spaces ( if there is a space on the credit card statement then enter the first 5 digits only with the space).
Here's 3 articles on activation and porting and the Refer a friend reward  if required:
1.How to activate https://www.publicmobile.ca/en/bc/get-help/articles/activation-account-set-up
2.How to port https://www.publicmobile.ca/en/bc/get-help/articles/choose-your-phone-number
3. Refer a friend https://www.publicmobile.ca/en/on/get-help/articles/the-refer-a-friend-reward
Stay safe.
@johnschwenk7  Make sure JavaScript and cookies are enabled. Need to wait for the previous session lock to clear before attempting that activation again.
Edit: Other customers are currently reporting similar problems so it might be a PM system issue. Just keep trying every hour and it will eventually work.
Dunkman
@johnschwenk7
You should check to see whether your credit card was charged?  If it was charged, try to insert your SIM card to see whether the SIM card works.
If not charged, you can clear cache, try a different web browser, or incognito mode.  Wait some time in between attempts.  Chrome incognito works well with this site.
iliketotalk
@johnschwenk7 Hi did you finish the whole process was your credit card charged did you try your sim in your phone
Staliger
@johnschwenk7 Did you wait for an hour and tried again with cleared cache and cookies?
