SIM did not arrive
cdmaruna
its is already more then 8 days still i haven't received my sim card
cellphoneuser1
Ignore the page that says Xpresspost and up to 7 days. Sim cards come by regular mail a lot of the time.
@cdmaruna
PM will take 3-10 days to complete your order then it is up to Canada Post to deliver your SIM…this may take up to 3 weeks.
dust2dust
You could always buy one from a corporate Telus or Koodo store. Check Find a store link on the bottom of this page. Call ahead. Start with Koodo. Telus stores may not want to give you the time of day.
Then when the sim arrives you can keep it for referrals.
@cdmaruna   SIM order from PM site could take as many as 3 weeks for it to deliver.
You can try to message PM Support for an update:  https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
If you need it urgently for activation, you might want to check with local Telus or Koodo store or get it from Amazon
https://www.amazon.ca/Public-prepaid-postpaid-Activate-Allinone/dp/B06X9ZGDWG
Timer
@cdmaruna
sometime it's take up to 10 to 15 day to be arrive.
if want to contact PM support team by private message CS_Agent  to see the status of shipping.
