SIM card
03-14-2023 07:55 AM
03-14-2023 09:25 AM
HOW it was locked?
Is it new card to be activated or it asks for PUK?
03-14-2023 08:14 AM
If you are getting any of the below messages, see details:
“SIM network PIN blocked. Enter SIM network PUK." is asking for the phone’s (often Samsung) “master code" after entering the wrong code too many times. Samsung and/or your previous carrier can give you this.
"SIM network unlock PIN" is asking for your previous carrier's unlock code - just contact them with your IMEI and they'll give it to you. If you enter this incorrectly too many times, you'll get the error message above.
03-14-2023 08:10 AM
I presume it’s a brand new Sim card?
To contact customer support agents, follow the below instructions
Use the ticketing system for a faster response time. Click here and type Customer Support Agent, then select Contact Us, then select Other (or the topic that more closely matches your request). Click the result which states Click here to submit a ticket and follow the prompts, or,
Send a private message to the Customer Support Agent by clicking here You’ll need to be logged into your Community account for the link to work.
