SIM card
josephmihalj
I bought a new iPhone and my SIM card doesn’t fit
@josephmihalj @It’s a 3 hole punch , press out the size needed for your phone
JK8
@josephmihalj
The SIM card separates into 3 different sizes. Just punch out the size you need.
dust2dust
Carefully press out the smaller gold contacts area from the larger frame. Unless your sim is many years old.
Adding - thanks HALIMACS
