07-28-2022 06:57 PM
Can I switch my SIM card to another phone without interrupting my account service?
Service
07-28-2022 07:17 PM
it's nothing changes on your account and plan everything in SIM card not in device,
SIM card is separate from device.
07-28-2022 07:05 PM
Excellent, nothing changes on my account/plan, correct??
07-28-2022 07:04 PM
Excellent, so nothing will change with my service or plan/account by doing a switch of phones??
07-28-2022 07:03 PM
Is there anything else to do? My service and account remain the same??
07-28-2022 07:00 PM
Yes, it is definitely possible. A sim card works independently of a specific mobile device. When switching from one phone to another, your service should still continue on the other phone. You may have to restart the phone that you put the SIM into, however.
07-28-2022 06:59 PM
Triple Punch SIM card fits most phones as it’s a Standard, Micro and Nano SIM card all rolled into one; simply remove the SIM card in the size that fits and insert it into your phone.
yes you can just turn off device take out SIM card and insert in other device and turn on
07-28-2022 06:59 PM
Absolutely - Yes. Turn both phones off, remove SIM from phone#1, plug it in (if it accepts same SIM size) into phone#2, power on and enjoy.
