SIM card
12-03-2021 06:06 PM - edited 01-04-2022 04:57 AM
12-03-2021 06:15 PM
Many Thanks
12-03-2021 06:13 PM - edited 12-03-2021 06:14 PM
Umioigi A7 should work according to Kimovil
Will UMiDIGI A7 work in Canada? (kimovil.com)
But from some questions on this Community, Umidigi sometimes is a bit trickier to have the APN setup properly for Data
FYI..
Public Mobile uses the following frequency bands:
4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS).
HSPA: 850 MHz, 1900 MHz (UMTS).
4G = B2 (1900), B4/B66 (2100 or 1700), B5 (850), B7 (2600), B12/B17 (700), B13 (700), B29 (700-Suppl. DL), B30 (2300)
3G = B2(1900) B5 (850)
Minimum recommended phone specs:
3G UMTS/W-CDMA/HSPA: B2 (1900) and B5 (850)
4G FDD-LTE: B4, B12
12-03-2021 06:10 PM - edited 12-03-2021 06:14 PM
Yes is will working with Public Mobile.
visit Here link to you can check it full information about your device.
- 4G LTE and LTE Advanced: 700 MHz, 850 MHz, 1900 MHz and 2100 MHz downlink and 1700 MHz uplink (AWS).
- HSPA: 850 MHz, 1900 MHz (UMTS).
