SIM card
Bub2
Can’t move it to my new phone
edited by computergeek541: changed category label as discussion isn't related to Community
CS_Agent
Customer Support Agent
Hey there,
just doing a little follow up and let me know if all is good, and if I can assist you with anything else and let me tell you Welcome to our Great Community Public Mobile!
If you have any other questions or concerns don't hesitate to reach us back or reach the community.
If the conversation is left unanswered for 24h, the system will automatically close it, however, for any matter or concern you can reach us or the community, or our best chatbot Simon.
We are here to help - 24/7! 🙂
Wish you All the best!  ^_^
Kind regards,
Claudia
Yummy
If you have physical SIM card just pop pit out and stick it into new phone.
Use adapters if needed.
If you try to move eSIM you will have to ask for a new one from PM (it should be free) and transfer number to new one and install it into new phone.
@Bub2
What was the issue? If it is a size issue, look carefully, the sim card itself has frames to remove to make it smaller, Nano size, for new phones
E-SIM_Tricut
