07-13-2024 06:02 PM
New customer (today). Need to know when to change to new SIM. Already confirmed to old carrier that I am switching but no one old or new has said to switch cards
Joining Public
09-27-2024 03:05 PM
thank you, just had the same question and this thread helped!
07-13-2024 07:58 PM
07-13-2024 06:16 PM
Hello @catherine73
If you have signed up with Public Mobile and you are porting your phone number from the other carrier, you need to leave the other carriers SIM card in the phone so you can get the porting authorization text. It usually comes within 90 minutes of you signing up and requesting the port over. IF you have already received the port request from your other provider and you've said YES... look at the top of the phone. Does it still have your old carriers name? Does it say... SOS... for example? If so, then the porting process is complete. Now you can shut off your phone, remove the old SIM card (but don't throw it out yet) and then insert the new Public Mobile card you have. Then reboot your phone. You SHOULD be up and running. If not, come back here and let us know what steps you've taken so we can help you troubleshoot it.
07-13-2024 06:10 PM - edited 07-13-2024 06:14 PM
@catherine73 Did you leave old providers SIM card in the phone to reply YES to the confirmation text to port to public mobile ? And this needs to be done with in 90 minutes window . If this time has passed you need to . Re trigger the port request . I’ll private message you the porting team number just in case . Also you old provider account needs to be active just a note
adding
if you have replied yes in the 90 minutes window . Try the PM SIM card in the phone and reboot it you should be good to go @catherine73
07-13-2024 06:09 PM
so you got the porting authorization text from old and replied yes?? Just wait till your old carrier sim does not work anymore, then change to the PM sim
