SIM card
Randi_63
I just installed my SIM card after not using it for 6 months. I changed the plan and now I have no service.
2 REPLIES 2
@Randi_63
Did you keep up with your monthly payment while you took out your SIM?
If you stopped payment for longer than 90 days. Your account will be closed, SIM rendered useless and your number will be returned to the carrier you got the number from.
@Randi_63
and you logged in and account showing active?
try to click 'Reset All networks" on your phone.  if you have another phone, also try your PM sim card there
if nothing works, please open ticket with PM Support
1. Open ticket via Chatbot (need access to My Account): At https://widget.telus.tiia.ai/publicmobile/publicmobile.html
    Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Log In", finally click "Click here to submit a ticket ↗"
