SIM card
TasneemLatrache
I still have not received my SIM card and it has been a month. What should I do ?
Chalupa_Batman
Hello @TasneemLatrache
Use this link to see if you can pick up a SIM card in your area.
https://www.publicmobile.ca/en/mb/pick-up-SIM
You can also purchase one from Amazon.
Don't worry about the fee you pay for the SIM card. You can reach out to a CS Agent via the ChatBot and they will refund your account the cost you paid.
HALIMACS
Here's what I would do @TasneemLatrache
Ask the customer support agents where it might be, then if they might agree to refund it and you pick one up at a corporate Telus or Koodo location.
They have done this for others.
  1. Use the ticketing system for a faster response time. Click here to create a support ticket, then type Customer Support Agent, then Contact Us,  or,
  2. Send a private message to Customer Support Agent by clicking here.  You’ll need to be logged into your Community account for the link to work.
@TasneemLatrache  That’s to long you can buy one from Telus Koodo store or order from amazon $4.99 there and ask support to reimburse you .
or send out another
submit ticket with support . using the chat bubble bottom right of screen
If that doesn’t work you can always send private message to support to fix
send  a  private message   To CS_Agents
