SIM card not working
ShawnGus
My phone lost the ability to send or receive calls (call failed message).
I swapped my SIM with my wife's and it worked fine---but my sim in my wife's and her phone didn't work.
-Don't have to be Sherlock to know the problem.  What is the solution?
-Will a new SIM mean that I have to get a new number?
Meow
Buy new SIM and do SIM swap.
Little problem is to find PM SIM. Look at official Telus store; you can order from PM site but it might take way to long to receive it. Ebay maybe?
@ShawnGus
Good trouble shooting to determine if it is the SIM or phone issue but sounds like a provisional/backend issue with your SIM. Just Submit a Ticket on SIMon Chatbot bottom of page or private message a CS_Agent on the envelope icon above.
dabr
@ShawnGus   It does seem like the SIM card is the issue.  No swapping SIMs with a new one doesn't affect your number or plan.
Once you have a new SIM card, just login to your self serve account using incognito/private mode and then select Quick Links/Profile and Change SIM and follow prompts to complete which registers the new SIM to your number and account.   Log out and reboot the phone if needed.
edit:  one more thing, of course, you need to replace the old SIM with the new one in your phone too after doing the above.
@ShawnGus it is good it is not a device problem.  Usually putting sim card in another phone will force a sim re-provisioning  but it didn't help in this case
please open ticket with support and they will refresh the account
1. Please open ticket via Chatbot (requires access to My Account): click this  Chatbot Ticket Link
Then click "Click here to submit a ticket ↗" to open the ticket submission page
Next, enter your Community login, then enter your question.  Finally use My Account login or 4 digits PIN to validate.
