06-20-2024
12:33 PM
06-20-2024
03:06 PM
computergeek541
Hello,
I placed an order for a Public mobile SIM card on 29th May, 2024, however, I am still yet to receive it (20th June, 2024) more than 15 business days later.
Thus, could you please look into this and kindly re-issue the SIM card, if needed?
Thanks,
Anand
06-20-2024 11:18 PM
@Neil11 wrote:Your best is buying bet is buying a physical sim card from a koodo/telus store or a mobile klinic store. Then contact CS_AGENT and they will credit you the cost of the sim $11.30 (10+tax). This was what I did after waiting 10days and my sim not arriving.
I disagree with this advice. The customer support agent needs to be contacted before buying a SIM card from the store. There is no guarantee that a customer support agent will agree to refund the purchase price of the SIM card, possibly resulting in the customer spending more than necessary.
06-20-2024 11:01 PM
06-20-2024 12:38 PM
Thank you! Just messaged..
06-20-2024 12:35 PM
hi @Ark2791
it shouldn't be that long. please check with support agent by direct message:
or you can also ask support to let you pickup from local Telus or Koodo store instead of having them to resend
