SIM card - invalid and SOS
AlainIsHere
Hi, I have purchased two new SIM cards. However when trying to activate them, one is being reported as invalid. The other has taken the phone to SOS and we cannot receive the OTP which is sent to it. These for new lines.
AlainIsHere
it's a used phone.
hairbag1
@AlainIsHere
I wonder about the cellphone you're using...is it a new phone or did you get it used from somewhere ?
AlainIsHere
Correct. They are for two new lines. The first registered under xxxxxxxxxxxxx (xxxxxxxxxxx) got stock at the last stage when the phone came up in SOS and we cannot receive the OTP. We used the app for this line.
For the second card, registered under my email, xxxxxxxxxxxxx when registering the SIM, using the website, it's reporting the SIM to be invalid. I use the app to make the account as well.
@AlainIsHere so, you are activat8ng new account?? You tried both SIM card numbers and neither work??  You were using the app to subscribe?? At which step in the Subscription process you are at??
