02-22-2026
08:30 PM
02-22-2026
10:10 PM
computergeek541
02-22-2026 09:35 PM
02-22-2026 08:31 PM
hi @Dinahw
physical sim? Sim card usually won't fail, so it is more a software problem
make sure you have no other sim card or eSIM on the phone, only PM sim there
make sure the PM sim is enabled (Turn on this line is toggled on) and with a label Primary
update carrier profile
Reboot phone and click Reset network setitngs
if same, then submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
(If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit ticket by direct message:
