SIM card doesn't work in a quad-band GSM phone
mbm
I bought and activated a SIM card at Walmart for my old basic quad-band GSM phone but it doesn't work. Only emergency service is available. Is there anything I can try other than buying another phone or have I just wasted fifty bucks? The phone in question is an unlocked dual-SIM Blu Tank T190i. The IMEI check on the Get Started page says that the phone should work. Can I request a refund for the plan, which I can't use? Thanks.
mbm
@computergeek541 wrote:
That's correct.  You'll only be able to use a 2g gsm phone on Rogers.  And even then, Rogers will be shutting down the 2g network in a couple of years.
OK, that's what I thought... So, can I ask for a refund and how can I do this?
@mbm wrote:
I am not quite following. There is no difference between the SIM1 and SIM2 functionality as far as I know. However, yes, I've tried both. It seems to me that Public Mobile is not compatible with 2G only GSM phones... I am guessing the phone has to be at least 3G...
mbm
will13am
@mbm, according to the link provided, SIM 2 should work.  Have you tried that?
