SIM card change
Skye2003
I’m trying to inset a new SIM card and don’t have access to my old phone number so I can’t get the required code
What can I do?
2 REPLIES 2
hairbag1
@Skye2003
Did you transfer your old number out to different network ? if you no longer have a Public Mobile account...now you need to download the Public Mobile app to your cell, create a new account using a different email address and then select a new plan. As long as the sim card you have is new and never been used, you can use it for the new account.
Meow
You can redirect authentication code to be delivered by email.
