SIM card PUK
alimohamed
hI, IMY SIM card PUK have been blocked
i need PUK number to un block my number
how i can contact a moderator
could some body help me please
@alimohamed
FYI, the Moderator have change their title as a CS_Agent (Customer Service Agent).
@alimohamed  If it’s a SIM card puk you need support to get it for you
send  a  private message   To CS_Agents
@alimohamed
is it really  sim card PUK??  what was the exact error message? Depends on the message, you have to ask the PUK code from different places
if it is really sim card PUk, and  If the message is “PIN unlock key (PUK)” or "Enter PUK Your SIM  Card, SIM cannot be accessed" or on an iPhone's status bar showing  "Locked SIM"
         open message support here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
          or use this direct link to open Chatbot ticket:  https://urlshortner.tiia.ai/Oyn1L6
            **Monitor your Community inbox (envelope icon on the top right) after the ticket is opened.  CS Agent will reply to you
there.
If it is a Samsung and if the message is "SIM network PIN blocked. Enter SIM network PUK." ,
      call  Samsung 1-800-726-7864 for a master unlock code.
      The only info you will need to provide is the IMEI and where the phone was purchased
If the message is "SIM network unlock PIN" or "SIM ME lock code NP" or "SIM not Supported" or on an iPhone's About->Carrier Lock showing "SIM locked"
          You have to ask the carrier where you got the phone from for the carrier help unlocking it.
           (Sorry, for this particular issue, PM support would not be able to help)
