08-24-2022 03:47 PM
I currently have an Android (Samsung) phone and am curious if I purchase a refurbished iphone from Public Mobile if I can use the same SIM card as the Android or will I have to get a new SIM?
08-24-2022 06:18 PM
Depending the model of the Samsung phone, the older Samsung uses micro size and the new models uses nano size SIM.
If it is a micro size, just carefully remove the micro spacer to the nano size.
The new iPhone uses nano size.
08-24-2022 04:05 PM - edited 08-24-2022 04:06 PM
SIM is universal; same can be used in apple or android based phones. Just watch for size and have adapters ready if needed.
08-24-2022 03:49 PM
@grosero hi you should be able to use the same card, depending on what size you are using now you may have to break it down to a smaller size
08-24-2022 03:48 PM - edited 08-24-2022 03:49 PM
yes you can used same SIM card and also any purchase device is coming with it free new SIM card.
The Triple Punch SIM card fits most phones as it’s a Standard, Micro and Nano SIM card all rolled into one; simply remove the SIM card in the size that fits and insert it into your phone.
