03-14-2022 03:22 PM
Can I take my The SIM card from my Samsung phone and put it in my Apple IPhone 11? Will my same phone number work?
Phones
03-14-2022 07:36 PM
Depending on the model of the Samsung, the newer Samsung phones and iPhone use the nano size SIM so it will be interchangeable between phones.
03-14-2022 03:37 PM
Yes u can 🙂
03-14-2022 03:32 PM
You may need to update your carrier profile after inserting the pm sim card in your iPhone.
03-14-2022 03:24 PM
@Duncanbc Yes you can. All your phone and account details are on the SIm card, so move it from.your Samsung to iPhone would work..as long as the physical size the same
03-14-2022 03:23 PM
@Duncanbc Yes!!
