SIM Card Not Working
LeviHughPalmer
I activated my SIM card yesterday and it isn't working. I can't use data, make or receive calls, or send it secure text messages. Something even stranger us that I do have the network connection speed bar thing in the top corner of my screen. I'll attach a screenshot of what I'm talking about. Anyways can I get some help?
48 REPLIES 48
brettster99
@LeviHughPalmer
Yay
I am so happy it is working for you now. Enjoy the savings and the public mobile family
@LeviHughPalmer yeah they tend to do that in the end lol. Tooo bad you had to go through so much to get there. Keep your head up!
LeviHughPalmer
@darlicious PM got my phone working finally! thanks for your help. I appreciate it
@LeviHughPalmer
Hopefully it's just a provisioning issue and you'll have a working service when you wake up in the morning.
LeviHughPalmer
@fdrcamb519 we are working it out still. I have verified my account for them and I am just waiting for them to reply now so we can actually figure this out.
fdrcamb519
@LeviHughPalmer
Did you solve your SIM, are they sending you a new one ????
LeviHughPalmer
@BearFBI Yes that is true. Hopefully if there is something wrong they can fix it.
BearFBI
@LeviHughPalmer well you could be that 0.1% chance that it may not be damaged but screwed up somehow. But I'm sure the moderators could fix that as the SIM retrieves its information all from their side.
LeviHughPalmer
@BearFBI Wow, hahaha! Thats pretty crazy! Well that gives me a little more assurance that the card isn't damaged.
BearFBI
@LeviHughPalmer Lol. I did an experiment. My old deactivated Rogers SIM still shows the config and APN settings when inserted into a phone. So i decided to scratch it up as hard as i can to see how hard it is to break. Well it took a LONG time. I stabbed it so hard there were several dents and it still worked. In the end i snapped it in half put it back together and it still worked. After a few more stabs it wasn't recognised anymore. Its hard to break a SIM.
LeviHughPalmer
@BearFBI Hahaha, no I have not 😂
LeviHughPalmer
@mpcdesign I have private messaged PM and they got back to my a couple hours ago. I just verified my account and replied to them. Hopefully they get back to me soon.
@LeviHughPalmer, has a moderator contacted you yet?
Be advised, they will probably contact you via the little envelope beside your profile icon. You have 24 hours to respond or they will think you solved the issue by yourself.
BearFBI
@LeviHughPalmer A defective SIM card is highly rare. How does a SIM become defective. A couple of metal contacts on a piece of plastic. SIM's are durable. Have you put your SIM through the paper shredder recently ?
brettster99
@LeviHughPalmer
If it is a truly defective SIM card then the moderators will send you another sim free of charge
LeviHughPalmer
@will13am I think it is possible it is defective but i would like to find out for sure before purchasing another one. I have contacted PM and hopefully we will figure out what is wrong.
@LeviHughPalmer wrote:
@will13am The setting I could find were what you said. I also tried my sibling's PM SIM card and it worked just fine. they tried mine and it had the same problem. I believe the problem isnt the phone. I think it is the card.
Does this "defective" SIM card work on any phone?  If not, then it truly is defective.
@LeviHughPalmer
On Tuesday morning the response time was 1 to 2 hours thru private messaging. But all the info was sent with the original message. Including name on account, address, email, ph #, pin # and the details of the issue. It was resolved within 2 hours of opening hours.
@LeviHughPalmer  The moderators work weekends...you should hear from them today just enable your email notifications from messaging and/or keep an eye on your private message box for a little number to pop up indicating a message from the moderators.
LeviHughPalmer
@mpcdesign Actually i was able to find all the different setting and they were all correct.
LeviHughPalmer
popping
@darlicious I have tried private messaging public mobile and I'm still waiting for a reply. If i don't get a reply in a couple days then i will try simon. I don't think i can chat directly to the moderators on the weekend.
There are 8 moderators online at the moment (May 16 10:47AM MT = 12:47PM ET)
There are usually over 10 moderator online during weekdays.
Sending private message directly without a ticket # on the subject line will take longer to receive a reply
You may get a moderator reply today or tomorrow.
LeviHughPalmer
Judging from the notifications on your phone, your data problem is APN settings.  Look through the network settings to locate access point names.  Make sure the correct APN setting is available and set as active.  Refer to the following knowledge base link on setting up the APN. The APN settings are as follows.  The inability to make calls is a different issue.  Since you have tried many account tweaks without effect, I suggest asking for moderator assistance.
APN Settings:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN type: default,mms,supl
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
fdrcamb519
@LeviHughPalmer
Welcome to PM, hope your phone is up and running could be frustrating, make sure do not disturb, and airplane mode are both off. Any suggestions help.
@LeviHughPalmer
Have you submitted you service request to the moderators via simon (?)  at the bottom right corner of the screen? Ask for a human and pick account specific issue. And ask for s human again. If it gives you the option  type in sim provisioning and submit your ticket. Expect a response in the morning hopefully before noon. Keep an eye on the envelope icon next to your avatar at the top right corner of your screen for a little number to pop up indicating a message from the moderators. Responding promptly to messages will speed up service times.
LeviHughPalmer
@popping I already tried paying a few extra dollars for my plan and it hasn't worked. Thanks for trying to help me.
LeviHughPalmer
@mpcdesign I use a Xiaomi and i cant find all the different settings. the ones i did find though were what you said. Thank you for trying to help.
mpcdesign
@LeviHughPalmer, did you also check your APN settings?
Settings:
  • Cellular > Cellular Data Options > Cellular Network or
  • Mobile Data > Mobile Data Options > Mobile Data Network.
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
Don't forget to save these settings and then select this APN as the active one. And I don't know if it means much, but do what I did, just copy and paste them exactly or type it exactly lower case and all (that's what I did when I first started with Public Mobile, because someone else suggested this to me at that time in 2017)
