SIM Card Activation
08-03-2020 04:58 AM - edited 01-05-2022 12:22 PM
I keep getting an 'Invalid SIM' message when trying to activate my SIM card. The number entered into the field is correct
Joining Public
08-03-2020 05:16 AM
@emzee if you are still having issues and can't seem to resolve it you can contact customer support here
make sure to check your inbox(top right corner envelope icon) periodically, for a response
08-03-2020 05:00 AM
Did you pass the payment section?
If yes check if your card was charged.
If it was charged put your sim card in your phone it will likely work.
If it does work and you were charged go to link below to create your self serve account.
https://selfserve.publicmobile.ca/self-registration/
If you were not charged. System locks sim for 50 minutes. Wait one hour, clear internet cookie/history cache open a fresh browser in incongnito mode and try again.
Don't forget a referral code for a $10 sign up bonus. If you used one and were charged and service works the credit will be applied within 72 hours.
Welcome to Public Mobile 🙂
