SIM CARD
contacto
Hello
I want to requi
@contacto
You can purchase a PM SIM from Canadian Cell Supplies from $2 and you can arrange for pickup if you are in Ontario.
Chalupa_Batman
Hey @contacto
You should look into seeing if your phone can do an eSIM. First one is $5 and after that they are free. But if you really need a physical SIM card, I'd try these two options and not order directly from Public Mobile as it can take up to 4 weeks in the mail and no tracking.
If you need a physical SIM, Amazon sells them. Click on AMAZON for the link.
Or locations near you that have a SIM. TELUS STORES
contacto
Sorry, I need a physycal SIM card to my current acount number
@contacto wrote:
Hello
I want to requi
hi @contacto
to quit ? or to buy?
to quit , if because you still have not receive the sim card, message support agent for update
if you want to buy new sim card, get PM sim card from Telus or Koodo store (https://www.publicmobile.ca/en/on/pick-up-SIM) or from Amazon.ca (https://www.amazon.ca/Public-prepaid-postpaid-Activate-Allinone/dp/B06X9ZGDWG/ref=sr_1_5_pp?sr=8-5)
