SCAM?
Charlie2004
Is this a scam. I recieved a message that my payment was accepted but account could not be set up
2 REPLIES 2
hi @Charlie2004 did you use the PM app to subscribe?
it is no scam, just some technical issues and PM support agent can help
you can  submit by direct message:
slusagm
PM support can help
 Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
https://productioncommunity.publicmobile.ca/t5/notes/privatenote
