12-06-2021 01:15 PM - edited 01-04-2022 05:01 AM
12-06-2021 01:30 PM - edited 12-06-2021 01:30 PM
@KL612 wrote:I saw Add on =0/ 200Mb together with
37.1/ 250Mb usage for Dec in my data plan details. Dies that mean the roll over is still there?
Yes, it is there
the 0/200MB is the add-on
the 37.1/250MB is the monthly bucket.
PM will use from your monthly bucket first. Once that is done, it will start consume from the Add-on Data. At the end of the cycle, any left over on the Add-on will be rolled over to the next cycle
12-06-2021 01:28 PM
12-06-2021 01:26 PM - edited 12-06-2021 01:27 PM
sign in to Self-Serve, to review your account, if you found at Available Funds: $$
Try To Purchase Add-Ons Using Your Self-Serve Account
To purchase Add-Ons using your Self-Serve account, follow these steps:
after you Add-on you have to do Rebooting your phone
what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
Overview Of Add-Ons visit Here link....
for more information about Managing Your Data Usage visit Here link to save your data...
and turn off background data, to save your data.
when your data limit used all, is will be off until next renewal cycle,
at public mobile 30 day Prepaid Service No fees extra charges,
if you can't fix it you need to Contact Customer Support Agent by CS_Agent, and Explain your issue to them can solve your issue, they are nice service Team the will help you 100%.
Here’s How To Contact Customer Support Agent by CS_Agent,and Submit a Ticket,
Good Luck..
12-06-2021 01:25 PM - edited 12-06-2021 01:26 PM
Any chance you got mixed up with your regular data bucket? regular data does not get roll over.
12-06-2021 01:18 PM - edited 12-06-2021 01:20 PM
@KL612 : Sounds like you used up the 200mb. Maybe post a screenshot of your overview page and payment history. Blank out personal info of course.
Edit: plan data gets reset at renewal and gets used first then. Add-on data is buy once and consume over time and gets used when you run out of plan data.
Are you sure you successfully bought the add-on?
