09-11-2020 04:44 PM - edited 01-05-2022 03:51 PM
Hello,
I live in whitehorse, I am traveling to Vancouver for three days can I use my phone in Vancouver as I have extra minutes in my phone
Please clarify.
Thanks
Shobana
Service
12-20-2020 06:49 PM
Thanks for the information
12-18-2020 09:58 PM
@raghu Until December 31 you can add free 500 calling minutes and 2GB data addons to your plan from the self-serve portal - a great compliment to the $15 plan.
Also remember incoming calls, and calls to tollfree numbers are unlimited with the $15 plan.
12-17-2020 04:57 PM
Thanks for your sugestion.
Shobana
09-21-2020 03:52 PM - edited 09-21-2020 03:53 PM
@raghu wrote:Thanks for informing this is a great plan for retirees but this only gives 100 min, can they give extra minutes maybe 50 for usage locally too is there a plan like that, Anyway all your plans are great!!!
Shobana
@raghu You can purchase the $5/500 Canada wide mins to supplement your $15 plan. These mins only get used when you've depleted plan mins and remaining unused mins from the add-on will keep rolling over every cycle until depleted. Just a reminder that add-on purchases are a two step process, so add your funds first and then make the add-on purchase.
BTW do you have the new version of the $15 plan with unlimited incoming mins?
Also with the current plans being Canada wide calling it doesn't matter if you are calling someone local to you or someone across the other side of Canada.
09-21-2020 03:45 PM
Shobana
09-11-2020 05:17 PM
Thanks for confirming the network is one
Shobana
09-11-2020 04:58 PM
@raghu Going from Whitehorse to Vancouver isn't roaming. It's the same network.
09-11-2020 04:54 PM
Thanks for confirming. It can be used in Vancouver as my plan allow calling canada wide so I can use in Canada
Shobana
09-11-2020 04:48 PM
@raghu wrote:Hello,
Please clarify.
Thanks
Shobana
Even if you have just Provincial calling you can call any BC number with your plan, but would need to use long-distance to call back to Whitehorse I would think. If you have a Canada wide plan you will have no issues at all.
09-11-2020 04:45 PM - edited 09-11-2020 04:47 PM
Hi as long as you have a Canada wide plan you can use it anywhere in canada have a safe trip
