Roaming
Dynomite
I cannot get data in the US. I have gone to cellular but the option to automatically switch over to roaming is not available switch data roaming on  and there is no option to do so
2 REPLIES 2
Socrates8567
Hello.
You may not be able to use data in the US with Public Mobile because you likely need to enable data roaming in your phone's settings, ensure you have a Canada-US plan or have purchased a US roaming add-on, and may need to manually select a network like AT&T or T-Mobile.
Also, not all phones work in the US. Please check the VoLTE list and enter your IMEI number at the bottom to make sure your phone is compatible.
https://www.publicmobile.ca/en/get-help/articles/volte
hi @Dynomite
turning on mobile data roaming is a phone option.
what phone do you have?
