05-30-2023 04:36 PM
My wife and I will be travelling in Europe in June. I’m wondering if for emergency use, the Public Mobile service will work in Europe? Just in case we get separated. From what I’ve read, it seems it doesn’t work in Europe.
thanks
Brent
Service
05-31-2023 12:28 PM
Thanks for all your replies!
Brent
05-31-2023 04:42 AM - edited 05-31-2023 04:44 AM
My wife and I went to Spain in November. PM won't work in Europe. We ordered an Orange Travel eSIM for €19.99. It works in all of the EU countries and the UK. 14 days, 8GB of 4G+ data, unlimited talk and text to anywhere in Europe, 30 min talk and 200 texts to overseas (e.g. back to Canada). Most eSIMs only provide data, no talk and text.
Make sure your phone is not set to dual sim mode. If your PM sim is left active, it will keep searching for non-existent signal and eat your battery. Have a nice trip.
05-30-2023 05:32 PM
HI @BrentB21
get local prepaid data sim card. Europe is cheap, and most can use across many countries
and if you have a newer phone with eSIm, check eSIM solution, even cheaper
05-30-2023 05:27 PM
Thanks!
05-30-2023 04:41 PM
@BrentB21 PM only works in Canada and the US no roaming in Europe sorry . Best to bet a local SIM card while you there much cheaper any ways
05-30-2023 04:39 PM
Public will not work at all.
A voip app like Textnow works marvellously. You need local cell data service or wifi.
Not so much for local calling though.
05-30-2023 04:38 PM
@BrentB21 Unfortunately, not. PM only provides 15 day roaming packages for US travel. You can get a local SIM or rely upon WIFI apps like Whatsapp or Skype. Textnow is another option.
