06-25-2019 08:38 PM - edited 01-05-2022 05:34 AM
06-26-2019 12:48 PM
If you need more data, you either change plans immediately, on the renewal date or ask a Moderator to assist you in renewing your plan.
Personally, if I were to run out of data, I'd buy the $30 1 GB add-on. Use it until it runs out, much better than needlessly changing to a different plan for a limited number of days.
If you're paying more than your regular plan amount every 30 days, look for another plan. The add-on is cheaper in the long run, as it will last until fully consumed.
06-26-2019 12:59 AM
Aaah, a trip came up needed extra data so was going to switch plan but just had plan renewed, that sucks, it be nice to have pro ration enabled to allow for users to add the plans in middle of month this way you also get them to change the plan date and make more money actually this way :).
06-25-2019 10:06 PM
@htcuser wrote:Hi, If i upgrade my plan to next plan though i just paid for current plan via autopay a night before, will i get credit or refund towards the next higher up plan, example if i just paid $25 and switched to $40 plan next day will i get refund or credit of $24 or something ?@htcuser No, you will lose the $25.00 that you paid and will be charged $40.00or I be out of the one months payment ? Also, is there Data roaming charges if plan and number originally in SK and move to Ontario ? example I have the $25 canada wide plan want to use data in ontario do i get data roaming charges slapped on ?Public Mobile does not have any roaming charges in Canada. If it works it means that it's included in your plan. Public Mobile is strictly prepaid.
06-25-2019 09:41 PM
@htcuser wrote:Hi, If i upgrade my plan to next plan though i just paid for current plan via autopay a night before, will i get credit or refund towards the next higher up plan, example if i just paid $25 and switched to $40 plan next day will i get refund or credit of $24 or something ? or I be out of the one months payment ? Also, is there Data roaming charges if plan and number originally in SK and move to Ontario ? example I have the $25 canada wide plan want to use data in ontario do i get data roaming charges slapped on ?
Going to Ontario isn't roaming. Roaming is connecting to different network. Public has no per use charges, but that isn't roaming.
06-25-2019 09:27 PM
Your entire plan is usable anywhere in Canada you connect to a Bell or Telus tower. No roaming at all.
06-25-2019 08:59 PM
06-25-2019 08:47 PM
You would be better off future dating whatever plan you'd like to change to that way you won't lose the money you've already paid for your current plan.
06-25-2019 08:41 PM - edited 06-25-2019 08:52 PM
No pro-rated plans for Public mobile. If you change plans, you lost whatever is left in original plan. Usually suggest change plans at next renewal date.
Data is Canada wide. No extra data charges for public mobile.
