02-28-2026 01:57 PM
02-28-2026 02:11 PM
Travel eSIM: If your phone is eSIM compatible, apps like Airalo.
Local SIM: You can buy a physical SIM card at major airports.
VoIP Apps: Use WhatsApp, FaceTime, or FB Messenger over WiFi to stay in touch with people back home.
02-28-2026 02:05 PM
02-28-2026 02:02 PM - edited 02-28-2026 02:04 PM
As a pre-pay cell service… there are no roaming charges, overage charges or any other charges other than your regular plan costs.
adding… your service will stop once you’re outside Canada unless you have a US / Mexico plan. Other than those 3 options… your cell will just not work.
02-28-2026 02:01 PM
Does that mean I cannot use my phone when I am in other countries
02-28-2026 01:59 PM
hi @Tonyall
PM has no roaming other than US and Mexico
With Mexico, you have to join the Canada/US/Mexico plan to use the roaming there
with US, you can join that roaming plan or buy US roaming addon
with other countries, sorry, no roaming at all
