12-17-2023 12:58 PM
12-17-2023 01:01 PM
Hi @Js12d
Public Mobile only works in Canada and the United States (with the purchase of roaming add on). You can not use your Public Mobile in any other country. If you wish to use cellular services while you’re in another country, you can look at https://www.airalo.com/ for affordable data plans and then download an app like Fongo and pick a local number to where you currently live. They do however charge for texting. TextNow is free calling and texting. You can use both of these VOIP programs via WiFi or on a data only SIM card.
12-17-2023 01:00 PM
PM only works while in Canada or the US with add ons.
12-17-2023 01:00 PM
You cannot as PM does not provide service outside of Canada/USA.
