05-13-2023
09:19 PM
05-16-2023
09:37 AM
Dunkman
Hello!
I'm planning to take a subscription with public mobile, but how does the give to the next part of the rewards work? Thank you for your help! Do you really manage to get savings every month? Thank you!
Rewards
05-16-2023 09:37 AM
@Maxence24 wrote:Perfect! and the forum part, to get points you have to answer frequently and help others, right? thanks!
That is correct. Contributing to forum will earn points as a community rewards. If you enjoy learning and helping others on a community forum, spend as much time as you want and see how much you will earn.
The exact formula for community rewards is unknown, but it is usually a combination of number of posts, number of bravoes received and solutions received. For example, to earn the higher levels of community rewards (ie, 15 points), you will need to spend several hours per day on the forum, which if you calculate the hourly "wage", it is very little.
05-13-2023 09:27 PM
05-13-2023 09:25 PM - edited 05-13-2023 09:27 PM
Generally speaking, you get 5% back in Public points with all the spending with PM . Once you collect to 15 points, you can then redeem for $15 bill credit.
If you refer friend to join, for each friend staying with , you get 1 point per cycle
So, the rewards and savings are real 🙂
More details: https://www.publicmobile.ca/en/on/get-help/articles/Public-Points-Rewards
