02-06-2022 06:55 PM
Earlier this week I created an account for a friend of mine but forgot to use my reference code.
Is there a way to correct this??
Thank you.
02-06-2022 07:38 PM
I read this the other way around. If the new account created is your friends and the missing referral code is yours then your friend needs to contact customer support to have your referral code added. If you help manage the account and know the account details then you can contact customer support on your friends behalf and ask for it to be added. You will see the $1 or 1 point depending on which loyalty program you have (rewards vs points) added to your rewards account immediately and your friend will see the $10 bonus referral credit added within 72 hours.
To pre-verify your account include your full name, address, email, phone # and 4 digit acct pin #
02-06-2022 07:01 PM
Hi @LHM1
yes,get in touch with Customer Support Agent (publicmobile.ca)
they will be Add.
02-06-2022 06:58 PM - edited 02-06-2022 06:58 PM
@LHM1 Yes, You will need to contact CS_Agent so they can add your referral code.
Here’s when and how to contact our Customer Support Agents:
02-06-2022 06:57 PM - edited 02-06-2022 06:58 PM
@LHM1 No worry, If it ws a miss, open ticket with PM Support. They are usually very understanding and will apply it back for you.
To open ticket with PM Support:
1. For faster response (2-48 hours), Click on the bubble in the lower right to request CS Agent assistance, or use this direct link: https://publicmobile.ca/chatbot.
Start with typing "Submit a ticket", click "Contact Us", click "Other" from the choices, click "Click here to submit a ticket". Then follow to complete the ticket submission.
2. Or you can Send a private message to the CS Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
**Monitor your Community inbox, envelope on the top right, after ticket is opened. CS Agent will reply and work with you via messaging there
