06-09-2017 08:27 PM - edited 01-04-2022 01:51 PM
Signed up for auto pay since started with public mobile but received no rewards at all??
02-11-2019 12:54 PM
@mimmo wrote:
@khanimran wrote:I am probably the very first user of PM, and auto pay. No rewards whatsoever. Also what is this $10 for 6 months off. I tried to explore in my account option, cannot find anything. Anyone has an idea?
@khanimran the 10$ off is for new activations only. If you are infact a legasy customer on a legasy plan I would recommend selecting a new plan before the automatic switch date. This will ensure you maximize the loyalty rewards.
@khanimran you may want to review the details of the announcement and the link contained within it: https://productioncommunity.publicmobile.ca/t5/Announcements/Effective-March-17-Legacy-customer-will...
02-11-2019 11:19 AM
@Dankaroo wrote:@SS wrote:
@SS wrote:still nothing but thanks for the suggestions!
As @ShawnC13 said contact @CS_Agent if there is an issue with the reward system on your end. Before doing so please take some time to read the rules and guidelines for the reward system.
For info on the reward system including when it applies please see here
If @stonechucker is correct in guessing you are on a legacy plan there is a clause for that in the link I provided. To stop being on a legacy plan simply access self serve, click on the Plans tab and then on the Change Plans sub tab.
@Dankaroo, you're replying to the original poster of this thread from 2017. There's only one user in this thread that is looking for recent information, as they responded to an old, and I believe resolved thread.
02-11-2019 11:19 AM - edited 02-11-2019 12:06 PM
Edit: Cleared due to no longer relevant.
02-11-2019 11:10 AM - edited 02-11-2019 11:59 AM
As @ShawnC13 instructed contact @CS_Agent if there is an issue with the reward system on your end. Before doing so please take some time to read the rules and guidelines for the reward system.
There is a clause for legacy plans in there. To change to a non legacy plan please sign into self serve, click on the Plans tab and then on the Change Plan sub tab to see your options.
Edit:
@stonechucker & @Anonymous
Thanks for pointing out that quoting error I must have hit the wrong reply button.
02-11-2019 11:04 AM
02-11-2019 10:46 AM
@khanimran, it sounds like you may be a current Legacy user, and if you're not aware, your plan will be losing call-centre access in the middle of March 2019.
For those of us who are not Legacy members, we are on what is called Reward Eligible plans, and AutoPay has a $2/30-day reward that is available to us.
As you're most likely a Legacy member, please look at the in-market and ready-made plans available, to get into the new phase of Public Mobile.
02-11-2019 10:32 AM
06-20-2017 12:37 AM
I removed the credit card and re-entered as suggested by one of the model citizens and the reward shows in the account now.
Thanks for the information though.
06-19-2017 11:35 PM
@SS, have you contacted a Mod about this as they should be able to clear this up for you.
06-19-2017 11:09 PM
06-10-2017 10:59 AM
Hi @SS
If the auto pay reward show under rewards on your self-service account, it should be ok. If not, delete your credit card and reset it. Thanks
06-09-2017 11:20 PM - edited 06-11-2017 12:32 AM
06-09-2017 10:16 PM - edited 06-09-2017 10:25 PM
06-09-2017 08:38 PM - edited 06-09-2017 08:41 PM
- Your reward for the 1st billing cycle should be in your available funds (you can see it when you login in your selfserve), and will be subtracted from your next payment.
- Your reward for the next billing cycle should show in the "My rewards" section of the selfserve and will be subtracted from your next payment.
- In the end, your first payment should have no discount, your second payment should have twice the autopay reward applied, and your next payments should have the autopay reward applied once.
If this is not the case, you should contact a moderator. I suggest you send them a private message. Be sure to include your Public Mobile phone number as well as a detailed description of your problem. Click here to know how contact them. They are available Mon-Thursday from 9am to 9pm and Friday-Sunday from 9am to 5:30pm (eastern time). They usually respond pretty fast to help requests!
I hope your problem will be solved quickly 🙂
