07-26-2023
01:39 PM
07-26-2023
02:13 PM
computergeek541
i just added my daughter to public mobile. Is there a way to put her on the old reward system? I don’t see the $2 off auto pay option either.
07-26-2023 04:48 PM
All new members that signed up to PM after January 25 will automatically be enrolled on the new Points system so no $2 credit for AutoPay. But she should get the $10 credit if she used your Referral Code.
She will need to collect up to 15 points for a $15 credit.
07-26-2023 01:43 PM - edited 07-26-2023 01:52 PM
@Nbhiker2023 No sorry all new activations are on the new point system . It’s been this way for a year or more now . So just don’t you ever switch the new points system yourself . She will earn points instead and once she has 15 points she can redeem it for $15 off her bill . You can also buy data and long distance add ons with points and enter phone draws too . Check it out in your rewards portal catalogue
Points rewards portal view catalog
Adding i sure hope you remembered to use your referral code for her to join so she gets $10 credit and you $1 every 30 days she stays with PM .
if you did forget by any chance . With her account contact support to see if they can apply it for you/her @Nbhiker2023
private message To CS_Agents click
VVVVV Link below VVVVV
07-26-2023 01:40 PM
No, all new sign ups get on the points system.
