08-20-2023 01:08 PM
08-20-2023 08:17 PM
@FlimFlam134 no you keep your old rewards no worries just be sure to change plan for next renewal and not immediately or you will lose money on your current cycle
08-20-2023 08:15 PM
ok thanks. I'm currently paying $40 for my 4G plan and I noticed its available for $39 so I'll be switching to that.
08-20-2023 08:11 PM
@FlimFlam134- No. And don't.
08-20-2023 08:05 PM
I'm currently on the old points system. If I change my subscription will I be forced into the new one?
08-20-2023 01:26 PM
@GerryMac No you get to keep your points until you use them up or leave PM so best to use 15 points for $15 off bill as soon as you get them . Because if you do ever leave for a better deal you will forfeit the points
08-20-2023 01:20 PM
Hey @GerryMac
Your points never expire.
Just adding. If you are currently on the old point system.... do NOT switch over!!!!
08-20-2023 01:12 PM - edited 08-20-2023 01:15 PM
you won't lose Rewards as long as your account is valid. Just don't voluntarily opt outta Rewards in favour of Points.
edited...my bad...I'm so used seeing the question asked about Rewards. You won't lose Points if upgrading.
08-20-2023 01:09 PM
No.
