Options
07-20-2023 03:35 PM
Can I re register an old SIM card that I had used in the past?
Labels:
Other
Options
07-20-2023 05:39 PM
SIM is one time use!
Options
07-20-2023 03:48 PM
@Doogi No sorry a SIM card can only be activated once . After that you would need a new SIM card
Options
07-20-2023 03:42 PM
Great thanks
Options
07-20-2023 03:40 PM
If the account that was attached to it is expired past 3 months and deactivated then no.
