03-10-2024 11:21 PM
Hi I recently tried a number transfer and after a bit of troubleshooting I realized that I had premium sms messaging turned off when I replied to the text from my old provider. It has been much longer than 90 minutes since then. How can I retry the number transfer?
03-11-2024 10:08 PM
Hey, When I get to this part where it says:
(i) You can find your SIM number (19-digits) on the back of the actual SIM card. If you are using an eSIM, please type N/A.
I am unable to type N/A and I am using an esim. It only allows numbers to be typed. I tried this on my laptop and phone. Any solutions?
Thanks!
03-11-2024 05:54 AM
@ZaneZ Have you tried rebooting the phone with the PM sim?
03-10-2024 11:40 PM
I'm positive yes. It says Premium SMS failed under my YES reply. I can make calls and use data with PM but incoming calls go straight to voice-mail. Texts don't work either. Only on wifi. I'm pretty sure that the transfer didn't go through.
03-10-2024 11:34 PM
@ZaneZ wrote:Hi I recently tried a number transfer and after a bit of troubleshooting I realized that I had premium sms messaging turned off when I replied to the text from my old provider. It has been much longer than 90 minutes since then. How can I retry the number transfer?
Please open a ticket to contact a Public Mobile customer support agent. That can be done thorugh the chatbot at https://widget.telus.tiia.ai/publicmobile/publicmobile.html or through the support section of the Public Mobile app.
03-10-2024 11:34 PM
HI @ZaneZ
if you called porting team and the system cannot find your number, usually it means the port was completed
But you sure you didn't reply YES to the text from Rogers?
and can you make outgoing calls using PM sim?
03-10-2024 11:32 PM
Hey I tried that and they said that they can't find that number...I am transferring from Rogers if that helps.
03-10-2024 11:23 PM
Check your messages I will pm you number.
