12-24-2021 01:18 AM - edited 01-04-2022 04:46 AM
Hi,
How do I retrieve my voicemail from a different phone (Android) so I don’t use the minutes on my own phone ? Thanks.
12-24-2021 11:38 AM
@PC99 the "dial your own phone number" solution already offered here is the simplest answer, but I just wanted to add for completeness another option you can use to dial into the voicemail server without ringing your own phone. There are local access numbers in many major centres across Canada, for which I compiled a list here:
12-24-2021 02:02 AM
Hi All,
I found the answer. Thanks.
12-24-2021 02:02 AM
Dial your number from another phone. When your voicemail picks up press "*" and enter your 4 digit voicemail pin#. And you are in....use a voip app like textnow or fongo while on wifi to call your voicemail.
