Response
Mah
Just wondering ussally how long does it take to get a reply when trying to transfer a number
Mah
I still cant get it to work still saying do contact mods
Have you ported your number over yet?
@Mah wrote:
Im trying to transfer my number from it was pc mobile then became koodo awhile ago and how do i port the number
If you are currently on Koodo postpaid, login to your self-serve account and click on the Plans and add-on tab. There you will see change phone number option. Provide your phone number and account number. Then check the Authorized box. The porting should complete instantly as we are on the same systems (Telus).
Mah
mimmo
Depends. Usually you can port by yourself in self serve. Unless it's Koodo prepaid.
Ports from cell companies take up to 2 hours usually.
If contacting mods expect a 24 hour turnaround time but upto 48.
If you provide more details then we can give you more accurate info.
